Alignment - CC Plates
I couldnt tell you :shrug: How did you CC install go anyway? I was gonna get a set while I was rebuilding the front end. Did you need any special tools? I have some really bad tire wear problems, the inside edge of the tire wears considerably faster than the rest of the tire...Im assuming thats a caster/camber issue? Or maybe my front end is made of jello :D
I got the four bolt MM plates. I was nervious cause I had never done them before. I am a rookie to a lot of do it yourself stuff. I did this myself with a lot of supervision. I was very easy. My impace gun helped a lot, but no special tools. I recomend the Maximum Motorsports plates. After seeing the install, how easy it was, and the quality of the products, he is switching his two stangs over to them.
this is a shop in federal way, WA. i dont know if u are up here or not. blood enterprises says they do all their stang alignments with these guys:
253-838-8088
not sure the name of the shop or the location cuz i need to go to. im gonna give them a call myself.
I had both the Cobra and the GT done at Les Schwab out in Battle Ground. They did an excellent job and I would highly recommend them. They took their time and were careful with my cars and allowed me to watch them as they did the work. I've got the MM plates on both of my cars and they had no problems with knowing what to do.
