O.K. I have done a search on an alignments and now I'm more confused. I have an eibach pro kit installed on an 05 GT. The alignment shop said there was no adjustment and showed me on the computer that the factory fix was to slot the two lower strut bolt holes. He said that I did not need camber bolts, which I have on order. The camber bolts say they go in the top strut bolt hole. So does the top hole adjust the camber and the lower hole adjust the caster????
It just doesn't seem right to me. Any help from someone that has had this done would really help before I elongate the wrong hole.
