Alignment HELP
My car is 2009 mustang GT. ok, i installed the springs, shocks/struts, and sway bars. I have camber bolts, but did not install them due to people on stangnet saying you wont need them with pro-kit.
Took the car to shop for alignment today. i told the mechanic, that if he cant fix the negative camber back to spec, to go ahead and install the camber bolts i had.
He called me after i left and said the camber bolts needed to be installed. they wanted $150 to install em, so I told him not to install them, and just get it as close as possible.
This is the alignment results:
----------------Front left-------------------Front Right
Camber------------ -1.3 --------------------------- -1.7
Caster------------- 7.5 --------------------------- 7.8
Toe--------------- .08 --------------------------- .08
The ford spec for camber is -1.5 to 0.0.
Why were they able to get the left in spec but not the right???
Or are they just being lazy or trying to get more money out of me???
Should i take it to a different shop??
thanks for the help :flag:
I installed the camber bolts and took it back to shop for alignment.
they got the camber on both the front wheels to -1.3
Is that still too much negative???
i dont want my tires to wear uneven.
is -1.3 ok?? and if not what should i tell them i want it at when i take it back??
thanks!! :flag:
