alignment problems after 5 lug conversion?
  • Thread starter Thread starter tiptopss
  • Start date Start date Mar 18, 2010
T
tiptopss
48
  • Mar 18, 2010
did anybody on here have any problems with alingment issues after doing a 5 lug conversion to there mustang? I am about to do the swap but read something about might needing longer a-arms, cause the fox ones are shorter, any truth to this? Also do you really need a bumpsteer kit? If I put the 95 spindles on and one half of the tire is almost off of the ground, what would a person do?
Repostyle
538
Portland, OR
Mar 18, 2010
  • Mar 18, 2010
If your car is lowered you need caster camber plates to fix vertical alignment, your spindles didn't do that. You will definalty need an alignment after the swap, the tie rod holes are much farther out on sn95's so your front wheels will point in.
Did your wheels sit straight up and down before the swap? If so, you did something wrong like mount the struts on the wrong sides of the brackets or something like that.
Repostyle
538
Portland, OR
Mar 18, 2010
  • Mar 18, 2010
Nevermind, I just re-read your post and see now it was hypothetical.
But part of my post still stands. You will need an alignment when your done.
281pony
2,681
Oly, WA
Mar 19, 2010
  • Mar 19, 2010
you do not need different control arms. you will need either sn95 balljoints, or a .330" spacer on top of your spindle. the fox balljoint stud is longer then an sn95. thus, you need to take up the slack with a hardened spacer.
people sell the specific machined spacers for like $13 shipped online.
T
tiptopss
48
  • Mar 19, 2010
thanks alot guys, but this is for a 85 gt, ive been told that the k member or a-arms are .5 inches shorter than the 87 and up gt,s. If this is true, I would think my front wheels would be away out of wack, and only longer control arms would fix the prob
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Mar 19, 2010
  • Mar 19, 2010
its not the a-arms that are shorter its the whole track width
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Y
Resolved 5 lug conversion
  • Ybfav84
  • Dec 21, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 21, 2024
AeroCoupe
