alignment wholes on strut tower?
The two rears (towards the firewall) are slotted from the factory to allow minimal camber adjustment. The one front (towards the front of the car) is not slotted, as Caster should not need to be adjusted. If you cannot get enough camber out with the provided slots, you can elongate them more to pull the camber out. IF you need to adjust the caster, you can also slot that hole. I do it all the time. I am an alignment tech. :)
Are you referring to the alignment holes/slots for the caster/ camber plates?
I could be wrong but I think you have your slots and hole backwards.
Like i said I could be wrong.
kreacher5.0 said:
no im talking about three little wholes that should have a rivet in one from factory mine hase no rivet so I was wanting to know wich whole it needs to ligne up to
So what you're asking for is where do you put the rivet in on your stock C/C plate?
My understanding is that the 3 holes you're referring to was used to set the Factory C/C plates when the car came off the assembly line.
If you had an alignment since the car has come off the assembly line the rivets are probably gone.
But I've been wrong before!
I wouldn't think because there in the same hole that, that would mean it's right.
My aftermarket C/C plates aren't setting exactly the same in the slotted holes is the reason I say that.
But I'm no alignment expert either.
the last time I took it to get it aligned they said there was no camber adjustment and left it alone it never drove the same after it kinda looks like the give me alittle toe out it makes it dart back and forth it also seems to turn in to much around curves
They must have changed them in different years because mine and every other one I've done is the opposite from yours LOL. But same difference. :)
To the thread starter: If they adjusted it to where it cannot be adjusted anymore, they CAN slot them MORE to get more adjustment out of it. You can also adjust the single hole for caster adjustment if needed or wanted more positive caster. If they said they cannot do anymore, they shouldn't be doing alignments. :) It's more time to do, which equals more money for them (I charge 1 hour per side to slot the holes if needed... does it take an hour? No... But that's what I charge if you want it done right.) so I don't know why they wouldn't want to do it.
Nick
