All gears go forward!
  • Thread starter Thread starter Marcsnothere
  • Start date Start date Apr 28, 2012
M
Marcsnothere
poplar grove illinois
Apr 28, 2012
  • Apr 28, 2012
87 5.0 HO AOD Transmission. Everything seems stock. (Just picked up car for my daughter a few months ago).
Before work began on car, tranny was slow to shift down to 1st, and reverse began to fight. So, Put it in the air, dropped pan, took out valve body. Took Valve body apart, cleaned, and reassembled Valve body with added shift kit parts.
During that time, I noticed the TV cable was disconnected from the Throttle body. Not sure how or why, but it was, so I reconnected it.
Fixed charging issue, ripped out A/C components, and fired her up.
Low works well. The car now really really likes going forward. Neutral... goes forward. Reverse, yup, goes forward. BUT, when in reverse, if I quickley give it gas, when the RPM's drop back down, the tires stop moving (Car is still on 4 jack stands) Park was being a pain.
Dropped pan again, checked valves, checked check balls. Went through everything on valve body, put it back up, same thing, but park seems happy again..
Im really lost on this one. I have only seen a couple posts online about such a thing, but seems I cant find an answer.
Oh, almost forgot, I did take the governor out and clean it well, and made sure to put it back in properly.
Im way lost on this, so any help is really appreciated.
Thanks in advance.
Marc
M
Marcsnothere
Apr 29, 2012
  • Apr 29, 2012
Anyone?
bentley429isBAC
922
188
84
CT
Apr 29, 2012
  • Apr 29, 2012
Stupid question but did you put it on the ground and try it that way or just on jackstands.
M
Marcsnothere
Apr 29, 2012
  • Apr 29, 2012
umm, not a stupid question. I have not taken it off of the jack stands yet. I didnt really think that would make a difference.
Also, probly not inportant, I did replace the Trans mount as it was crap.
bentley429isBAC
922
188
84
CT
Apr 29, 2012
  • Apr 29, 2012
Lower it down and try that for the heck of it.
OonDeanisS
902
Danbury, CT
Apr 29, 2012
  • Apr 29, 2012
this is just a wild guess but MAYBE the shifter is sliding past R and N and somehow engaging D? i really have no clue how auto shifters work, but maybe this will give someone else an idea?
Hawkeye_306
69
Apr 29, 2012
  • Apr 29, 2012
A poorly adjusted TV can cause strange things to happen. See if it goes into proper gear with the TV disconnected to indicate if its TV adjustment problem.
M
Marcsnothere
Apr 29, 2012
  • Apr 29, 2012
Did that today, zero change. I tore into it again today, just to mkae sure I did the vavle body right, and everything was correct. I did notice today, that even while in park, the motor wont rev up normally. Its in park, but acts as if someone locked the wheels in drive, and gave it gas. Make any sense?
So sounds like I need to find a cheap tranny to get me by for now, that way I can safely learn to rebuild this tranny to my likings eh?
jetmech807
1,195
326
164
Crestview, FL
Apr 29, 2012
  • Apr 29, 2012
That would tell me that drive is still engaged and the only reason the wheels aren't turning is because the lock that is engaged when park is selected is keeping it from turning.
Sent from my PC36100 using Tapatalk 2
joshprice
Clarksburg, West Virginia
May 4, 2012
#10
  • May 4, 2012
  • #10
the plastic gromet breaks on the throttle body leting the cable drop usually on efi cars with a aod drop line psi drop burns direct clutches verry quicky if there burnt to gether it wil move fwd in neutral rev and bind in park hate to break bad news but rebuilt a bunch of aods because of this
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
