Having a problem with my 93 GT 5.0 5spd. It's running poorly and i need some insight to a possible wiring problem.
Tried to run my KOEO test today and it wouldn't work so I had to run a wire from the battery ground straight to the STI trigger to get the test to start. Came back with these codes:
21 coolant temp sensor out of specified range
22 map sensor out of specified range
23 throttle position sensor out of range
34 EVP voltage above closed unit
67 Nuetral drive switch or circuit
81 Thermactor air circuit
82 Thermactor air circuit integrated controller circuit
Second set of codes were
22, 34, 51, 53, & 54 which are just more sensors out of range.
Am I right in assuming I have a broken signal return wire somewhere due to the fact that it connects to just about every problem I'm having right now. Codes and the KOEO test not wanting to start?
