All sorts of the leaks
savegoodautonfg
1,085
Hey well before i went to bahamas a week ago i gave my car to my mechanic he fixed the crank seal and the rear output shaft leak. now i get under the car after he is done and i got it at home and i see between the 2 there looks to be another leak. any ideas what it could be?
Well i got the FRONT CRANK SEAL and REAR OUTPUT SHAFT done already. and it seems like all over the transmission there is some visible fluid. i can't find a real leak of where its all coming from. i can't find it newhere. im not really sure what else it could be?
Did you put any sealer on the bolts that connect your flywheel to the crank. These bolts holes go completly through and will cause a leak that looks a rear main seal leak. Very common but not to commonly known. hope this helps.
