I finally got a power adder for my 2001 mustang gt. It is the allen supercharger 9 psi kit. Here are the kit contents for those who dont know:
- one-piece cast aluminum manifold
- air to water intercooler
- mechanical water pump
- Eaton M90S-ported supercharger
- integral bypass valve
- fuel pump voltage booster
- 30 lb/hr fuel injectors
- billet fuel rails
- custom chip
- all brackets, belts, hoses and hardware for an OEM quality installation.
- upgraded mass air meter
I am mostly concerned with destroying my stock 2001 gt engine. I noticed that a lot of people on this forum run 9 psi without any fear of breaking anything on their motor. But I found it weird that the allen company that makes this kit says that running at 6 psi is safe but says that you should only run at 9 psi if you have beefed up the bottom end. What do you guys think? I know a lot of you run 9 psi on stock motors. Is this safe, or is allen supercharger correct?
http://www.allenengine.com/01must1.html
- billet fuel rails
- custom chip
ALLEN has a fine kit and it is a viable alternative to the KB kit.
? What are the 9lbs numbers of Allen kit?
