Alright, last night I finished installing hawk pads on all 4 corners. I started with the back and finished with the front. The fronts were very tight...the caliper and pads barely fit over the rotor. I had to use a little force to get them to go on. Well, I put everything back together and started the car and the brake pedal feels very hard. Also, when I moved it into the garage, it felt like the brakes were on even though they were not. Is there too much pressure in the master cylinder now or something? Do I need to sand down the hawk pads a little bit? I have not bleed the brakes but I will if I need to.
