3G Alternator Getting Hot Hot! What is the deal??
Hi all,
I need an alternator guru that can give me some clues as to what the heck is causing my 3G Alternator to get piping hot after less than a minute of idling.
Background:
1. I have a 65 Mustang Coupe. I put an 87 5.0 EFI motor in it and went with a 3G alternator setup. Alternator is brand new.
2. Motor is just basic Crank, Water Pump, Tensioner, and Alternator on my serpentine belt. Super basic.
3. With the belt off the alternator spins very smooth.
4. Alternator charging cable goes to a 175 amp mega fuse, then to the starter solenoid where it shares a mounting bolt with the positive battery cable.
5. Alternator seems to be grounded just fine.
6. I've checked and rechecked my wiring schematic and I think I'm fine. The schematic I'm using can be found at:
http://fordfuelinjection.com/public/alternator/3G-ALT_wiring.gif
7. I am also following the guidelines from: Ford Fuel Injection 3G Install Tech
My alternator is exactly like the one pictured in the last link above.
Anyway, after my first start up of the car with the EFI swap I knew I would have a few bugs to work out. But this one has me stumped. I don't hear any squealing on the belt, car idles great. Everything seems fine but the Alternator gets really hot really fast. Probably would melt the belt clean off if I let it.
Any ideas???? Tonight I'm going to check for shorts and see if I have any major draw on the system. Other than that I can't figure it out.
Thanks in advance,
jrl
Hi all,
Background:
Thanks in advance,
jrl
Any suggestions are well appreciated..
