Put a charger on the battery and ended up starting the car today with a battery voltage of 12.86. As soon as I started it, I checked the alternator output and it was at 12.8. I then checked the three wires that plug into the alt. They all read the same as the alt. output except for the stator which was a little above 10v. The battery voltage read the same as the alt voltage (so problem with the battery charging). When I rev the engine up, there is no change in voltage.
Now I would be alright with 12.8v but after letting the car run for about 5 minutes, the alt output voltage starts to drop. About 2-3 minutes after that it was down to 11.98v.
Autozone tested my alt and told me everything was ok, but I don't know if I believe them. Any ideas?
Dave
Dave
