the underdrive pully makes the accessories spin less... to free up some power your engine was using to turn them. The pully will only hurt you unless it's smaller than the one ont here now.
My understanding was that if the alt spins less then it is charging less. I just did the 3g swap and had to put a 1 7/8 inch pulley on it to get it to charge right....that pulley was a midget compared to the stock 3g pulley.
I also bent a fan blade before I took it to the shop to get them to remove it with air tools. The second time i replaced the pulley I just put it in a bench clamp and tightened it down....then was able to remove it with no problems.
A smaller pulley will charge better, an larger one will load the engine less at the same rpm, and turn the alt slower at the same rpm.
I tried the underdrives on my 79 and it would not charge or run the ac at idle. Took them off the next day.
They work fine on my 82 to charge the battery and run the electric fan. In normal driving the 4.10 gears make up for the rpm the pulley lost and it does charge.
However, the bottle heater is still too much for my 82 style alternator at idle, so I try to be careful when I use it.
