Alternator Pulley
SuperDust22
The Power of Pixie Dust?!
Oct 19, 2003
1,821
Gilbert,AZ
I have a set of ford underdrive pullies. I was wondering if I can just put back on the stock alternator. I am going to run a little amp and sub in the back and I needed the little extra power from the alternator.
wytstang said:
I would fix that electrical demon that you have before putting something thats going to drain you power even more
Of course that is first on my list. I am going to put the stock alternator pullie back on and get a new alternator harness. And I am going to check all my ground wires and stupid stuff like that.
BTW-- Does anyone know where to get a new alternator harness. The only choice I have right now is to go to the junk yard and get one.
The belt tensioner worked just like it is supposed to. With the U/D pulley, which has a larger diameter than the stocker, the belt fit tighter than original. So, when I switched back to the stock alternator pulley the fit of the belt was better.
i don't know why but i had no charging problems what so ever and i had two amps and two 10" woofers. but of course, before i put the pulleys on i got an 850 amp battery and that was that. no need to get a new alternator or anything else. and like some said, there shouldn't be a problem with your belt, it stays the same.
