ALTERNATOR PULLEY
lxwants12's
506
I have an underdrive pulley kit on my car now...and a 3 g alternator...i was wondering if i am supposed to swap the alt pulley for the stock one cause i heard it will help charging a little more...
Hmmm... good question. I've never tried to buy a pulley that way so couldn't tell you for sure. Maybe a trip to the junkyard for a fried alternator might be the way to go.
I`ll take a guess here and say that a 3g with a stock 3g size pulley probably won`t charge well at idle with a underdrive crank pulley.
Every 3g alternator I`ve seen comes with a huge 2-1/2" dia pulley.
Try a stock 2g size pulley first and if that`s not enough try a smaller od alternator pulley,if your running a underdrive crank pulley.
A local alternator rebuilder should have a good selection of smaller pulleys.
i tried to swap pulleys from a stock 2g alt and the pulley fits but i had to put a small spacer behind it because it touches the alt housing when tightend, and it doesnt give the nut alot of thread..only goes on like 1.5 turns and i dont feel good about that, so i left it alone...my alt is from pa performance...can i use the pulleys from that link SLEEPER on my alt...i dotn wanna buy it and it fits the same way as the one i just described
94-95 3g`s are different than 96 and up 3g`s.The cases are a little different and the pulley spacing is different.(I`m pretty sure a stock 2g pulley will fit a 94-95 3g without issues).
www.aspracing.com makes a 1-7/8" OD alternator pulley,but it only fits 94-95,3g`s.
They said if I used a washer as a spacer it would push the pulley grooves too far out causing the belt to walk off.They could make a custom 1-7/8" od pulley,but it was pricey.
E-mail Pa-Performance and ask them if they have any smaller pulleys that will fit your alternator properly.
In my case I have a 96 Taurus 130amp,3g alternator and a local rebuilder had a 2g size diameter pulley with the correct spacing that fit my 3g.
Being that I work in a parts store and get a lot of old alt's coming through all the time as core/defect returns, I was able to swap the pulley that came with my 3g with a smaller one from an old 3g someone had turned in as a core. The big ol' honkin' pulley that came on my 3g wasn't charging enough as it should have at idle, but with the smaller pulley swapped on there, it's perfect. Doesn't dip the slightest bit, even with lights on, wipers going, and vent blowing full-blast. The pulley I swapped on there is a nice, shiny brass piece, too, so I got a bit of gold-lookin' bling-bling going on underhood now, too. :D
