alternator question
  • Thread starter Thread starter theconductor
  • Start date Start date Aug 2, 2008
theconductor
337
96
74
Roseville, CA
Aug 2, 2008
  • Aug 2, 2008
Looking to upgrade my alternator soon. I'm not sure if I need 130, 170, or 200 amps. What are you guys using and why? I do have a decent stereo with a couple of amps, and I hope to put in an electric fan this winter....
Thanks
-Kyle
jwzg
237
Prattville, AL
Aug 2, 2008
  • Aug 2, 2008
130 amps is typically the minimum needed for the typical bolt-on Fox w/stereo. I use a 200 amp Powermaster I bought used for $50, but I really don't need that much. www.paperformance.com is probably the best source for brand new 3G alternators and they carry a lifetime warranty.
HISSIN50
34
129
Aug 2, 2008
  • Aug 2, 2008
Be sure you compare actual output numbers with various alts you're considering. You might find an advertised 130 that has very similar output to a 160, for instance.
justagt
143
  • Aug 2, 2008
PA
A vote for the 130A
jwzg
237
Prattville, AL
Aug 2, 2008
  • Aug 2, 2008
If you live close to a pull-a-part, you can make a pretty cool harness for it for next to nothing if you don't want to buy the harness from PA. See here for details.
theconductor
337
96
74
Roseville, CA
Aug 3, 2008
  • Aug 3, 2008
Thanks for the input. Seems like a 130 should work fine. Especially since I don't drive the car all that often.
Kyle
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
Electrical Alternator not charging after terminator 2 install.
  • Sfab79
  • Aug 24, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Electrical Inaccessible starter solenoid from wire tuck, what are my options for an alternator upgrade?
  • AnthonyA1234
  • Jan 16, 2025
Fox 5.0 Mustang Tech Feb 8, 2025
Mindseye007
