  • 1994 - 1995 Specific Tech
Alternator questions
  • Thread starter Thread starter 302GTS
  • Start date Start date Aug 27, 2009
302GTS
If you need herpes, I'm your man!
Apr 20, 2009
481
Largo, FL
Aug 27, 2009
  • Aug 27, 2009
After a 1,500 sound system being on my (I believe) stock alternator, it's quickly wearing out after 3 weeks or so...
I found a local guy on CL selling a 4.6 alternator, which I've heard are better than the 5.0 stockers. Will it swap on directly, and what's the amp rating on those? 130 or 160?
HISSIN50
34
129
Aug 27, 2009
  • Aug 27, 2009
It probably won't have the output you're looking for. Some of the smaller case alts actually can have less output than a big case 3G (our alts can put out ~160 amps stock)
What makes you think it's the system eating the alt's? How are they failing? Or is your stocker getting ready to take a dump? It could be that it was marginal before (maybe it had already dropped a diode) and now the system is finishing it off.
I'd look at aftermarket 160 - 200 amp 3G alts, or just get a parts store stock replacement with a lifetime warranty (Shipping an alt out for warranty work is a pain). One considerating: with aftermarket stuff, they often have near 100 amps of output near idle. A parts store version might not (at least not without overdriving it).
99FiveOh
2,051
20
99
J-Ville, FL
Aug 27, 2009
  • Aug 27, 2009
Well for one, saying "4.6" alternator is being vague since the 4.6 had no less than 3 different style alternators from 96-present.
Now, while the later 4.6's use a 6G style aternator which is more effiecient, it still only puts out 130 amps. And the 96-98's used the same exact 3G that our cars came with (different mounting setup for 4.6 alts).
And I agree with JT, your stock alternator was probably on it's way out before the sound system was installed.
302GTS
Apr 20, 2009
481
Largo, FL
Aug 27, 2009
  • Aug 27, 2009
I think the stocker may have been on its way out to begin with, IMO. The car would idle funny at times and a/c and accessories messes with with idle a good amount. Clicking on my headlights would cause the battery guage to drop a tiny, tiny bit.
As for a 130 being enough... I've got a friend of mine who currently is running a 3,000 watt system with 2 15 inch subs in his Ranger. The guy's a genius when it comes to sound/electrical systems. He works more wiring magic with cars than I've ever seen. He says a 130 amp alternator should work fine for what I have. A 160 would be good, but the 130 will work fine.
The system's on its way out in the next couple weeks anyway. I've got a friend who has been in the process of doing a TT swap on his 300zx, and the system's from his car, which he's loaning me until his car is up and running.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
G
Quiet my 2015 GT on the cheap
  • gsrblack
  • Feb 12, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Apr 16, 2025
gkomo
W
Help with 95 GT
  • waynewl34
  • Apr 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 5, 2025
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
