alternator troubles
  • Thread starter Thread starter 88stanggonebad
  • Start date Start date Jul 11, 2006
88stanggonebad
59
  • Jul 11, 2006
hey guys my alternator is being a little b***h. when i took it off for the engine swap i forgot to label where all the cables go. so now im not to sure where to hook them up to. i have 2 single cables with rubber covers and one cable that splits into 2 cables. with one end having a small ring for one of the posts on the alt. and one big ring that looks like it would be big enough for the bolts that go on the head. a ground maybe?
xoxbxfx
3,959
Southlake, TX
Jul 11, 2006
  • Jul 11, 2006
if Im correct (pretty sure... the one on the red boot is the positive, the white is stator wire and the big black is the case ground. Use a test light and put it on the positive terminal of the alternator...but the probe end on the big ring and spin it a bit and see if you can get a little glow going. If so, its the ground.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
R
Electrical Trunk Mount Battery and Cut Off Switch- Need Help
  • Rcdgl
  • Nov 20, 2024
Fox 5.0 Mustang Tech Nov 20, 2024
nickyb
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
