alternator upgrade for 390?
67gt
38
I want to upgrade the alternator in my car I have heard a lot about the 3G. My main question is if I go to the junk yard what car/year should I pull one out of that will fit in? Is the wiring the same as my stock alternator? Also do I just take the pulley off of the old alternator and put it on the new?
Thank you
I just did the swap on my 69 Mustang 302. I used a Ford Taurus 3G from
a 3.8L 1993. Do a Search for 3G there was a wiring diagram and more
detailed info in this forum. It was pretty easy except I had to lengthen
the lower Adjuster Bracket. The alternator cost $35.00.
Steve69
I haven't got mine mounted yet but the old oem pulley did not line up. I had a March and it lined up perfectly. You will need to run 4ga wire if it is 130 amp. PA performance has a wiring kit.
