Alternator
281CI96Coupe
233
I advise you, if you ever get a rebuilt alternator, think twice....they really suck. I had mine for about a year now and it barely charges at idle. Oh well! I am just wondering where can I order one online for a decent price. Anyone, have some good websites to go to? The highest price I've seen was 225 for a new OEM one. :rolleyes:
-Nate
-Nate
hmmmm, how long have I been preaching this:D
Or you can have the worst luck in the world like i do and buy a brand new OEM FORD (not rebuilt)alternator from the said website above and its dead out of the box. But you only find out after going crazy for days wondering wtf could be wrong with the car and then finally towing it and paying a shop 2 hrs of diagnostic time to finally figure out, it must be crap for luck, but i got a dead brand spanking new ford alternator. :bang:
Actually the #1 reason for a newly-installed alternator to fail is ...
Installing a new alternator with a deeply discharged battery installed because the old alternator failed and let it run down.
new or rebuilt alternators do not like that, as they are going to run for a long time at an ultra-high load re-charging that dead battery plus supplying the power to run everything else. They will overheat, windings or insulation will fail, diodes overheat. Etc.
If the alternator fails, either charge the battery with a good charger, or replace it. Don't fry your new alternator by making it overheat re-charging a dead battery. It also needs time to break-in without being called on to produce 100+ amps right out of the box. You can smell 'em when this gets done. Put your hand on one treated like that and you can get burned...
Never thought of that. So thats what that burning smell through your vents is? the Alternator? Also, what if the Alternator is charging while driving but barely at idle, does that mean that the battery is shot when you put a new one on?
easy test. Hook up a voltmeter to the battery. You should see about 12.5 volts or so if it is ok. Now crank and let the motor idle. You should be seeing around +14 volts now. If not, the alternator is bad (or the built-in regulator). Finally turn the lights on bright, and anything else in the car (blower on high, A/C on, etc). Voltmeter should still be reading +14 or wherever it was after you cranked it. If so, it is good. If not, again either the regulator has failed or you have a few failed / shorted windings which reduces output.
Any parts store can load test the thing once you take it out of the car... but the above will generally be just as accurate.
I have seen alternators that seem to charge, but can only produce 2-3-4 amps, rather than 50+ at idle. They won't cut it and when you turn the headlights on the battery will start to discharge. That's why we check the voltmeter... Alternator should be able to hold around +14 or whatever the regulator likes at idle with no load, even with the lights and other stuff running... that is a "poor-man's load test" and its pretty accurate at diagnosing these kinds of failures. You can always get a second opinion at the parts stores that test them...
