  • 1994 - 1995 Specific Tech
alum D/S install Q
  • Thread starter Thread starter urban96
  • Start date Start date Sep 6, 2006
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Sep 6, 2006
  • Sep 6, 2006
ok ive read that you need to mark your d/s when removing it so that when you reinstall it, its still in balence.
but what do you do when you install an alum one for the first time? just bolt it in and go?
divit250r
314
Columbia City, IN
Sep 6, 2006
  • Sep 6, 2006
I just chucked it in there, myself. I know it happens sometimes, but I don't understand how the driveshaft goes out of phase anyway. Even the stockers are balanced as a shaft assembly, not with the specific trans and axle the car gets. Anybody got any idea what does it??
Scott
Guero
2,148
Sep 6, 2006
  • Sep 6, 2006
When i installed mine, i never checked for anything i just swapped them out, and no shaking or nothing afterwards
ProKiller
3,064
15
78
PA
Sep 6, 2006
  • Sep 6, 2006
whoa wait a second....an aluminum driveshaft is balanced? i had pretty bad vibration 3k when i would get into after i installed the new motor. I'm running the stock driveshaft again because that made less vibration. there is still vibration at 3k and it clears up by 3500-4k but its better.
how would you go about checking for balance?
94-302-vert
1,947
NE CT
Sep 6, 2006
  • Sep 6, 2006
Any driveline shop can check the shaft for the proper balance...
HISSIN50
34
129
Sep 6, 2006
  • Sep 6, 2006
The OEM driveline *components* are loosely balanced at the factory. This would be closer to a dynamic balance, which is why marking the DS is important. You can sometimes see yellow reference dots.
An alum DS is statically balanced so it matters not what it's phase is. Prokiller, there were some fairly large weights on my Alum DS to get it to spec (from the factory). Do you have those?
reddy351
560
12
38
Columbus, Ohio
Sep 6, 2006
  • Sep 6, 2006
Since it happened AFTER you installed a new engine, I would look to the tranny/engine mounts. If these are worn or mis-aligned, the whole drivetrain would cause a vibration.
Methodical
1,192
11
59
Clinton, MD
Sep 7, 2006
  • Sep 7, 2006
Just slap it in and go driving and have some fun. You should not have any problems unless there were other problems that were being masked.
R
rockin_rick
968
Sep 7, 2006
  • Sep 7, 2006
Your trans or rear end can also cause this vibration that you are experiencing. I'd suspect the rear end if it's never been rebuilt...
Rick
urban96
3,464
Syracuse, NY
Sep 7, 2006
#10
  • Sep 7, 2006
  • #10
thanks for the info guys
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
