Aluminum Driveshaft: Banging on E-brake cables?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Anyone else have this problem?
I keep adjusting my e-brake (Ford Racing cables for SN95 rear disk) but every time i release the handle and hit a bump, the metal equalizer bangs off the aluminum driveshaft I have?
Kinda annoying. Anyone ever deal with this??
Do i need to adjust my cables tighter?
I did. The adjustment is too loose. Tighten up the adjuster on the cable and it will raise up so that it does not rub on the driveshaft.
I guessing that you did the modification that eliminates the self adjuster on the parking brake lever mechanism. If so, the extra few turns will probably fix your problem.
Yes, i did all that.
I don't think i'll be able to cut off the threaded portion with the driveshaft still attached. But i do have a good 4" or so just hanging off doing nothing. I wonder if some really strong pliers or cutters would do the trick? :shrug:
Try a cutoff wheel in a dremel or die grinder. There is a little more room when you jack the car and put the jackstands under the body jackpoints. This allows the rear axle to drop a pretty good distance and helps to make more room to do the job.
