i am going to buy one in an hour you guys sold me on it.now if i could get an even trade for a 3.73 for my 4.10
I would say the aluminum shaft is about half the weight of the stock steel shaft.
the guy i bought this from told me it might need some new u joints and that they are fairly cheap .where can i buy this from?
any auto parts store. is it a ford racing one or one from a windstar?
oh yeah the only way to tell if it's a FRPP one or one out of the vans is the $200 price diffrence OR if they havent changed the rear u joint. But then also like i stated MAKE SURE it's out of a 96 or 97 cause they are welded NOT pressed in ends on them. NONE of the FRPP ones have pressed in ends either, so if you buy one make sure the ends are welded. OK so buy the drive shaft remove the rear u joint. remove your stock rear u joint take both of them to the parts store and tell them you need to make this go to this. problem solved. peace
john![]()
SMOKEDYA said:oh yeah the only way to tell if it's a FRPP one or one out of the vans is the $200 price diffrence OR if they havent changed the rear u joint. But then also like i stated MAKE SURE it's out of a 96 or 97 cause they are welded NOT pressed in ends on them. NONE of the FRPP ones have pressed in ends either, so if you buy one make sure the ends are welded. OK so buy the drive shaft remove the rear u joint. remove your stock rear u joint take both of them to the parts store and tell them you need to make this go to this. problem solved. peace
