Aluminum DS worth the cash?
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
i have always considered an alum DS but its over 200$ and thats alot for something that doesnt really do much.
i have had a small DS vibration for a while and i figured it would help. plus people on here reccomended it also in a recent topic.
so do the alum DSs usually come vibration free. will there be any other difference besides smooth operation.
its less rotating mass but i doubt it would be noticed.
let me know your guy's expierences with them...
The situation that Shaker noted is where the Alum DS shines. Unless one is seeing some vibes from the stocker, I'd leave well enough alone. I'd get an Alum DS as a fix for an issue, not for performance gains alone. It is lighter but also has a shifted Moment (it's diameter is greater than a stocker), which offsets it's lighter weight when seen from a performance perspective.
FWIW, the stocker's are not difficult to twist or bend. Couple that with a fairly low critical speed (and aftermarket gears), and it's not hard to see why people get vibes.
Good luck.
I got mine because I had a bad vibe above 70, Me and my brother installed it and as soon as I pulled away from his house it seemed smoother. When I took it out on the highway I was amazed at how far 80 dollars and 35 minutes could go. If you are looking for performance this isnt gonna help too much. If youre attempting to fix a drive line vibration, an aluminum drive shaft will quite possibly be your thing.
i didnt know they were a bigger diameter than stock, my mufflers are quite large and on big bumps the pass. side hits both the frame rail and driveshaft(usually framerail), if i get a bigger aluminum shaft it will rub the muffler..looks like that's out
~Mark~
the last owner had the exhaust installed by the worst possible guy locally...it doesn;t amaze me that it doesn't fit right, i have done some work to the exhaust myself to make it better..with enough fitting i'm sure i could make it work, does anyoneknow the actual diameters of the two driveshafts?
~Mark~
~Mark~
I don't know the exact diameter of the Aluminum DS,but I could tell you this it will be a tight fit inside a bolted together Lakewood driveshaft safety loop,minus all the washer/spacer . About 1/2 " all around clearance. I had it on my last Mustang before the new style SL comes on the market. And it was a pain to get the clearance needed . But once on it is okey.
Good luck.
Listen to this guy:nice:
