Am I missing parts?
my$100project
208
Today I finished bolting all parts onto the engine. I have two bolts that bolt into the back of the heads, next to two carbon filled holes that look like they run with the exhaust. However, I have no brackets that should bolt up to here. I bought it as a basket case (torn apart, parts missing). It still has the cats so I'm guessing they where on there at time of disassembly. Anyone have a pic of these tubes? Or know exactly what I am missing? How bad will this change my idle ---a/f ratio--o2 readings-if I plug them?
Well, seeing as how the tubes have somehow disappeared, I guess I'll have to remove my egr. I'll run a search to find out what all needs to be done and the effects it will on my o2 reading, a/f mixture etc. thanks for the help
That sounds like the air thermactor ports and not EGR ports. You can plug them up no problem, the tube that ran from the smog pump to the back of the heads will have to be left off if you plug them. Mine are plugged with no problems.
Tim
Tim
Agreed.
The bolts are not necessary unless you are bolting the tube on for the smog pump. If not using that, clean out the carbon filled holes and you will find some threads. The same style inserts that are in the front of the heads can be used to plug them...or a couple bolts for that matter (5/8-11 IIRC) You cannot leave them open -- it will leak.
