  • SN95 4.6L Mustang Tech
Amp Question
  • Thread starter Thread starter varad
  • Start date Start date Aug 7, 2007
V
varad
26
Philadelphia
Aug 7, 2007
  • Aug 7, 2007
Hello. I am installing an amp in my 1999 Mustang. I am using the factory head unit so I already bought a line converter (to get the required RCA cables). My question is where can I install the remote wire to turn the amp on/off? I checked all of my fuses with a test light and every single one lights up with the key off. I need a fuse that only lights up with the key on and with the key backwards to wire the remote wire to. In other words, I need a wire to tap in to that only is active when the key is on or backwards. I am thinking the cigarette lighter? Can someone please help?
stangdrvr06
42
  • Aug 7, 2007
The lighter i believe gives u 12volts at all times. On the back of your factory unit i believe its the black/pink wire. Hook it up to that and test it with the key on and off but im pretty sure thats it.
V
varad
26
Philadelphia
Aug 7, 2007
  • Aug 7, 2007
hey stangdrvr06, thanks a lot for that suggestion. that should make this install much easier. I didn't take the reciever out yet but it is one wire that is black and pink?
Shiroelex
There's nothing worse than aut
728
Westland, MI
Aug 7, 2007
  • Aug 7, 2007
There's a fuse under the dash that only has power on key on. I found at least two. I'll get you the fuse number, if they are the same in 99 as they are in 2002.
V
varad
26
Philadelphia
Aug 8, 2007
  • Aug 8, 2007
really you did find 2? Yes every single fuse lit up brightly with the ignition off. Maybe there is some kind of safe mode for the fuse box where they hold power? Anyways, I'm gonna check out that wire on the back of my factory receiver and see if that will work.
V
varad
26
Philadelphia
Aug 8, 2007
  • Aug 8, 2007
I cant even get the factory receiver out. I dont have a DIN tool but I tried a clothes hangar and it is just not budging out. Any suggestions?
snidehockey
131
Orlando, Fl
Aug 8, 2007
  • Aug 8, 2007
just get an inline splice and pull from the back of the lighter like they suggested. the plastic around the shifter pops out...and there ya have it.
Heratik
51
Ann Arbor, MI
Aug 8, 2007
  • Aug 8, 2007
I just used my owners manual and found the fuse under the dash that powers the stereo. I then wedged the wire in with the fuse itself. Perhaps not the most secure method but it isn't carrying much current and I haven't had any trouble so far. My amp goes on and off with the ignition and unless you remove the cover to my fuse box you can't tell that I hillbilly rigged it.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 9, 2007
  • Aug 9, 2007
BAD
Are you serious ? This is just plain BAD. You should at least use something like this:
http://www.allelectronics.com/cgi-bin/category/196550/Quick_Splice.html
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Aug 9, 2007
#10
  • Aug 9, 2007
  • #10
I'll post for reference (2003 model)
Clicky for pictures of amp install on mach 460
V
varad
26
Philadelphia
Aug 11, 2007
#11
  • Aug 11, 2007
  • #11
thanks for all the help everyone. I just bought the din tool and took the factory receiver out. The black/pink wire is perfect. It has power with the ignition on and with the key backwards. It's just like installing the remote turn on wire if you had an aftermarket receiver.
V
varad
26
Philadelphia
Aug 11, 2007
#12
  • Aug 11, 2007
  • #12
Okay now i am having trouble installing the line converter. On the left rear speaker, there is a gray wire and a brown wire. On the right rear speaker, there is an orange wire and a gray wire. Does anyone know what is positive and what is negative?
stangdrvr06
42
#13
  • Aug 13, 2007
  • #13
LR Speaker +/- gray/lt. blue - tan/yellow
RR Speaker +/- orange/red - brown/pink
For the line out put convertor u will have 2 channels for the rca's to come out of on one side and 4 wires i believe on the other side. ( if im wrong then don't do the next steps) Take the solid color wires twist them together and take the wires with the black stripes. Twist them together. Connect the solid to + . The stripes to - and you're done.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
