N notched1 New Member Jun 5, 2004 31 0 0 ontario,canada Apr 2, 2005 #1 Apr 2, 2005 #1 When installing a 3G 130amp alternator is a 200amp inline fuse the only size that should be used(as listed in the PA Performance wire kit) or is a 150amp sufficiant ?
whtpny New Member Dec 8, 2002 338 0 0 Spokane WA. Apr 2, 2005 #2 Apr 2, 2005 #2 I would use what they recommend for warranty puposes. You can get the fuse and holder from PA for 26 bucks anyway. May as well use the right stuff.
N notched1 New Member Jun 5, 2004 31 0 0 ontario,canada Apr 2, 2005 #3 Apr 2, 2005 #3 whtpny said: I would use what they recommend for warranty puposes. You can get the fuse and holder from PA for 26 bucks anyway. May as well use the right stuff. Click to expand... good point. cheers
jrichker StangNet's favorite TOOL In Remembrance. Thank you for your contributions Mar 10, 2000 27,512 2,813 234 Dublin GA Apr 2, 2005 #4 Apr 2, 2005 #4 See WWW.partsexpress.com for the fuse & fuse holder. Fuse @ $3.90 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=071-952 Fuseholder @ $5.80 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-630 4 gauge black wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-196 4 gauge red wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-194 4 gauge ring crimp terminals (package of 5) $3.25. http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=095-584
