Amsoil /347 Questions
ricky50
322
Miami
Hey guys and girls,
I have a recently built (has not been started up yet) all new 347 and i wanted to know when i should go from regular oil to synthetic and how many oil changes after initial start up and when?
for those of you that you that use Amsoil, why do you use it rather than Mobil one, Redline,Royal Purple?
I am leaning towards Amsoil myself and need to make up my mind on this once and for all.
Please tell me your experiences good and bad with all synthetics, By the way what grade would be good for my na 347 in Florida weather?
Amsoil dealers, feel free to chime in here please.
If i join (Amsoil) the preferred buyer deal, how cheaper can i get my oil per quart?
I run Mobil 1, because it is easy to find locally.
Redline was a PITA to get a few years ago.
Most people will suggest waiting until the rings have fully seated to switch to syn. oil.
I would wait until after 1,000 miles. That is probably VERY conservative though.
A couple hundred miles should be plenty, I would think.
jason
I'm with vristang.
Keith Craft suggested somewhere in the 3,000 mile range if you want to be totally safe. 1000 miles or after and I would do it if you want to insure longevity.
Synthetic fluids have different lubricating minerals than your "average joe" oil.
i have mobil 1 5w30 in my 306 right now and its been there ever since assembly. i have royal purple 10w30 waiting to go in at the first oil change. its been started up a few times but never driven due to the lack of exhaust and aod tv cable. do you think it will break in ok? sorry to hijack thread...
I also prefer to wait for a couple of thousand miles before switching over to synthetics.
So long as the dyno oil you're using is a quality oil then there's absolutely nothing to loose by running it for a couple thousand miles to be on the safe side.
I personally am in no hurry to switch...been told the motor will continue to free up for some time as miles are stacked on, and synthetics my infact prevent true break in that dyno oils would promote. Best filter available and keeping it clean is best in my mind...I'm a fan of GTX and a K&N filter for the oil, but that's just me.
When I did my 347 CHP told me to wait at least 500 miles before switching. As far as the oil changes go, I changed mine right after the initial break-in, 250 miles, 500 miles, 1500 miles and then the regular 3000 miles.
superhuaman said:
so i need to change the oil then... :( at least i dont need a new filter
I hope you're kidding..spending all that money on an engine..installing it and your worried about the $20 dollars to ensure the money is not wasted...sorry should not even be an issue to pull the drain plug and replace the oil and filter.
