-AN Chart
i don't know where a chart is other than doing a google or yahoo for it. i think that you just take the number you are using and put in a fraction with 16. -4 an would be 4/16. then reduce that down to 1/8. hope this helps.
found this on summits website:
What's a -6 or -8 AN?
OK, so you're ready to order fittings for that new fuel system you just got. Now there's only one thing: What's a -6 or -8 AN fitting?
"AN" (Army Navy) Sizes were established by the aerospace industry. The measurements represent the O.D. (outside diameter) of rigid metal tubes. Basically, dash sizes are the numerators of fractions with a denominator of 16.
EXAMPLE:
-6 is equal to 6/16 in. which is equal to 3/8 in.
-8 is equal to 8/16 in. which is equal to 1/2 in.
In the examples above, a -6 AN fitting would work with a pipe that has a 3/8 in. O.D. A -8 AN fitting would be used with 1/2 in. O.D. pipe.
Here's a simple chart, just in case you don't want to do the math.
-02 AN is equal to 1/8 in.
-03 AN is equal to 3/16 in.
-04 AN is equal to 1/4 in.
-05 AN is equal to 5/16 in.
-06 AN is equal to 3/8 in.
-08 AN is equal to 1/2 in.
-10 AN is equal to 5/8 in.
-12 AN is equal to 3/4 in.
-14 AN is equal to 7/8 in.
-16 AN is equal to 1 in.
-20 AN is equal to 1 1/4 in.
-24 AN is equal to 1 1/2 in.
-32 AN is equal to 2 in.
The most commonly used fittings are adapters. These adapters connect an AN fitting to a pipe thread fitting. Most fuel pumps, regulators, and canister type fuel filters, come with pipe thread inlet/outlet ports. In order to use braided line, the ports need to be changed to a AN type of fitting. This is when a "pipe to AN adapter" is needed.
The most popular sizes used in fuel systems are the -6 and the -8 AN, although some high performance fuel pumps and regulators require a -10 AN fitting.
One extra item to be aware of: all AN flare fittings are 37 degree flare angle. That's the same angle as commercial hydraulic fittings, which are interchangeable with AN fittings for most non-aviation applications. Don't try to use a 45 degree automotive flaring tool, you get leaks and flares that crack and fail.
Some parts resources:
http://www.aircraftspruce.com/index.php
http://www.amazonhose.com/default.asp
http://www.sacskyranch.com/
http://www.wicksaircraft.com/catalogDetails.php
http://www.swagelok.com/products.htm
http://www.parker.com/Products/EPD/
http://www.aerospace.eaton.com/products/fluid_conveyance/hoses/index.html - stainless steel hose & fittings.
