an other cam question
rickd93_lx
162
i .planning on installing it my self i have a 93 cobra engine with 30,000 miles on it, would there be a problem reusing the roller rockers i would change the rods of course
I don't see why there would be any issue reusing those rockers as they do not have high miles. They are crane cobra specific 1.7 rockers. just make sure that the cam you are putting in there will clear the pistons with that 1.7 ratio. What cam are you swapping to?
rickd93_lx said:
I would just check the valve clearance. F cam is .512 lift but with 1.7 rockers its .544. IT should be ok but you don't want to have to take everything back apart once you find out that valves are slapping your pistons.
