D
Any updates Nightfire
Just finished acquiring all the miscellaneous parts. I've got everything now. Now it's just a scheduling issue. Since the car is my DD and I've been extremely busy with work lately, Im just trying to find time to get it done. I figure that it'll be down for at least a week, maybe more since I have to trailer it 300 miles to get it tuned![]()
Are you going to come this way to San Antonio or where at?
Any quick guesses as to what a 3.2 and a 3.6 pulley would boost with the stock crank/pullies on a stock heads/cams 2V with full exhaust?
instead of using the procharger Big Red unit, which is extremely loud, I'm going to use a dual Tial 50 setup on my FRC build, play with them and the springs to make sure I'm not losing any ET in between shifts.Would you guys suggest H or I beams? Both are 4340 alloy.
You can mount just about any BOV in trick locations. Main thing is to keep compressor surge down, all will do it if you pick the right size/spring. A perfect BOV for a D1SC(1400cfm blower)would be a Tial 50. I ran 2 different Vortech BOV's, 1 turbosmart, and then settled on a Tial 50 (#3 spring) with the 3 different blowers on my C6. It sounded the best, worked great, and had no flutter.
I've got a brand new turbosmart BOV in the box if you want it. I'm not going to have a use for it as it will be too small at 1000rwhp, but works great up to 700rwhp as in my YouTube videos. But I'll admit, I have a little ricer in me. Here is my Novi 1500/T trim(1200cfm blower) with a Tial50. Complete street sweeper and opened at 1500-2000rpm under cruise to scare the women and kids.instead of using the procharger Big Red unit, which is extremely loud, I'm going to use a dual Tial 50 setup on my FRC build, play with them and the springs to make sure I'm not losing any ET in between shifts.
BOV's are really just physics on a centri. You can ask any 10 guys in the vette racing community. You might get 10 different responses, probably the same with the mustang and import community
Depending on the flange you have you could also use the large Red Procharger Valve, it use the same mount as the large red bypass valve. Otherwise I am also a TiAL fan or Race Part Solutions has some lower cost alternatives that work very well also... or if you want very loud look into a Blitz.
