Anderson Cam B-31 Or B-41
Grabbin' Asphalt
2,029
310
124
Atlanta, Ga
B-3 ......218/226 .542/.542 w/ 1.6 rocker
B-31.....218/228 .544/.544 w/1.6 rocker 270/280 112 108
B-4.......224/232 .542/.563 112
B-41 ...228/236 .544/.544 w/1.6 rocker
Think I'm going to chose between these two, 363 stroker, dd, street manners are very inportant, what cha think?? AFR 185 heads, 3.55 gears, 5 spd. Anyone got some experience with these or know of a buddies set up??
Reactions: 85rkyboby
What they said ^^. A close friend of mine has the B31 on his weekend racer 88 hatch. Edelbrock heads, V2 S-trim, Saleen intake, 302 bottom end.
It makes around 56o to the tires and runs 10's.
Are you looking to buy new? I hate to be the custom cam guy, but if you are spending that much cash on an engine, it may be worth the extra $100. That being said, I am doing my current build with mostly used parts. I have a n41 cam and have been happy with it. I bought a n71 cam used, and was going to run it, but changed my mind. For an ots cam, anderson makes good products, and they are billet. Comp charges extra to get their $300 cams in billet.
Joe
Oh man "Lumpy" is cool! My Trick Flow cam is very lumpy and I love it! Nothing cooler than listening at idle to my blower whistle and cattless exhaust being shook up by a "lumpy" cam.
Its all about the cool factor to me.
coolness eghh? hmmm i think this is a lead in the 'status kill' mystery....
anyway i totally get the idle to x rpm power curve desire..... hows that play on a 331 or 363?
dont forget to check out Comp cams XE274HR im running a custom NX274HR i love it great torque & power yeah its lumpy but i think you will get use to it
XE274 is very similiar to NX274 what im running only difference mine has wider lobe separation for nos or blower both are great off the shelf stroker cams and custom grinds i dont think they charge for. The XE270 im not as familiar with but comp website has great info
Why don't you contact one of the cam gurus that everyone recommends and get a custom grind? Direction I'm going in on my next build. I just wouldn't run an OTS grind in a dart block build. I would try to maximize everything I want out of it(in your case idle quality,power,and possible forced induction). Plenty of quality OTS cams out there but...
