Another 5 lug conversion/rim tire question
ponyboy19
1,640
I'm planning on a 5 lug conversion on my 92 and want to be able to swap rim's and tires back and forth from my 92 to my 95. I have a set of 17x9 cobra R's and a set of 18x9 00 cobra R's. Will one or both of these sets of rims work with the cheap axle and rotor conversion like this one on my 92. I have the links to most of the swap info pages but I see more info on the disc brake conversion and so on to go with it.. I plan on staying with stock brakes and stock length axles. I think either of these rims will work but I'm looking for some people to verify that. Will I need spacers or anything?
http://cgi.ebay.com/ebaymotors/ws/e...d=1,1&item=7979550566&sspagename=STRK:MEWA:IT
Any pics of a 87-93 with 00 cobra R rims would be cool if you have them :nice:
BlownStangGT said:
with the "cheap" rotor 5 lug conversion up front on ur fox, you will not be able to run the 18" y2k r's, you must do the sn95 swap to be able to run the y2k r's up front.
I'm more concerned on the 17x9's fitting the 92. I plan on running the y2k R's on the 95 when the big and littles aren't on it. The 17x9's off my 95 should be ok on the 92 then?
