Ok,
I just finished installing the FMS Center e-brake cable with the threads,
thought that was going to take up the slack in my e-brake and the actual brakes themselfs,
Now Ive noticed because of the amount of brake dust that my Rear Drivers Caliper has the most dust, Like MAD dust,
And the drivers side front caliper is second worst for dust,
The passenger side calipers front and rear have almost no dust and the passenger front has barley even started to score the rotor,
Could this be as simple as Air in the system? (even though I have bled these brakes so much the pedal feels like your stepping on concrete)
However the second you start the engone the pedal feels softer, (Im guessing because I used a V6 Brake Booster?)
Now the E-brake problem,
After installing it I tensioned the cable with the bolts on the thread, cable felt tighter but not good enough,
So i kept going, Even with the cable almost out if threads the rear wheels still didnt hole the car as well as I wanted them to,
So I left it,
Started driving this mornign mand noticed the rear felt like it was dragging a bit and sure enough Id obviously done the cable up too tight as the drivers rear wheel was smoking, (peoples faces lol)
Again drivers rear does all the braking,
So
Whats up?
Can anyone offer some advise?
I backed off the adj cable this morning and the car rolls now and no smoke lol, But the E-Brake is CRAP as per usual, and my pedal is softer than Id like,
I dunno if its a bleed issue, Im thinking mabey my rear calipers need replacing with new ones? (got them froma junkyard)
And the piston was VERY hard to twist back for the drivers rear (the one thats doing all the braking it seems) and easier for the passenger rear to twist back
I know its long but Id like to have nice brakes
Dont get me wrong they STOP when I need them too, Much better than the Fox stuff, I dunno mabey I was over expecting???
So I left it,
So
Whats up?
