Another Cam Question
T0rk3d
45
Hello, I got a set of AFR 165s. I have 1.7rrs. I have a edelbrock performer Rpm gasket matched to 1262 felpro. I am looking into getting a cam to finish it off. I want a decent chunky idle so I have been looking at something with about 112 lsa.
The question i have that I cant really seem to find, is how much lift/duration before I run into PTV issues? I was looking at doing the E-303 or TFS 1 with the 1.7s which would put them at .530/530 @220/220 for ecam and .530/542 @221/225 for the TFS1. Im going insane trying to figure out what cam to go with. I dont want to get a custom cam. Will the TFS cam work or any other recommendations? Please let me know!!!:Track:
why not custom?? for the extra 150 dollars u can insure no ptv issues and you will be about to get the idle you want all while making the most power possible from your combo.... well worth it I would say.. :shrug:
Torked,
A custom camshaft is always the better way to go, but it cost a little bit more than a typical camshaft. But you get something for that extra $.
- Better driveability
- More power
- More manifold vacuum
- You will get the sound as well, it is just part of it
- Professional assistance
www.flowtechinduction.com
Ed Curtis @ [email protected]
I have done business with the above a couple times with good service and parts. He sells your AFR's as well.
http://www.wighat.com/fcr3/camtruth.htm
Buddy Rawls contact is [email protected]
Now, remember that lift is not a factor of piston to valve clearance. It is the period of overlap that causes piston to valve clearance.
The period of overlap is when both valves are open at the same time when the piston is at the top of the cylinder bore. The exhaust valve is closing and the intake valve is opening.
When a valve is at peak lift, the piston is well down into the cylinder bore.
Also, LSA (lobe seperation angle) is not set in stone from camshaft to camshaft. LSA is figured out by the individual timing events that can vary from camshaft to camshaft.
Two camshafts can have 112 LSA, but have different individual opening and closing events.
Let us take two common camshafts with the same advertised LSA.
B-303 Camshaft
224*/224* 284*/284* - .480"/.480" - .300"/.300" - 112* LSA - 107* ATDC /117* BTDC - 3,300-5,100 RPM
Overlap: 60 degrees.
1.6 Rocker Ratio
Intake Opening: 5* BTDC
Intake Closing: 39* ABDC
Exhaust Opening: 49* BBDC
Exhaust Closing: 5* BTDC
and...
Trickflow Stage 1 - 221*/225* - 275*/279* - .499"/.510" - .312"/.319" - 112* LSA - 108*/116* - 2,000-5,500 RPM
Overlap: 53 degrees.
1.6 Rocker Ratio
Intake Opening: 3* BTDC
Intake Closing: 38* ABDC
Exhaust Closing: 4* BTDC
Do you see how the TIMING EVENTS are different between camshafts, although they have the same LSA.
So take the B-303 opening and closing events for the intake and exhaust:
Intake Opening/Closing - 5+39 = 44. 44+180 = 224* Duration.
Exhaust Opening/Closing - 49-5 = 44. 44+180 = 224* Duration.
224 is the answer on the intake and exhaust. If you look, this makes up the DURATION at .050", since the timing events were taken at .050".
So to find LSA divide the durations by 2 and average them.
Intake: 224/2 = 112
Exhaust: 224/2 = 112
Average: 112 + 112 = 224/2 = 112 LSA
As another example, you can look at the Trickflow Stage 1 opening and closing events.
Intake Opening/Closing - 3+38 = 41. 41 + 180 = 221* Duration.
Exhaust Opening/Closing - 49-4 = 45. 45 + 180 = 225* Duration.
Good Luck:nice:
Duration at the lobe lift (cam) does not change, because the camshaft is, what it is. It does not effect valve events or ramp rate at the camshaft either.
But, say you are at 100* of a 224* duration, and you have 1.6 roller rockers, and then you add 1.7 roller rockers. At that very duration point, the valve will be open further, thus making the cam to potentially act bigger.
The increased ratio does speed up the valve opening and closing events.
Larger roller rockers do not just increase peak lift.
From the very moment the valve lifts to the very moment it closes will not change, but when you start getting some lift, the duration starts to increase at very small rates.
I would not buy a roller rocker to get more duration, so just get the right camshaft to begin with:nice:
Atleast, this is my basic understanding of it...
To add to what was said above, which is great info, check out this link. I read this thread three times before it started to click. I have it book marked, because I am a nerd.
LSA isn't the whole story when it comes to having a meaty idle. Heck you could tune one in, I did this on the stock cam as an exercise when I was learning the TwEECer.
http://bbs.hardcore50.com/vbulletin/showthread.php?t=40629
Adam
Thanks for all the info guys. Cams are like another language to me at the moment. I would like to run a power adder, but at this time since im still waiting on my real job to become open and im going to college this is just my have fun not too crazy daily driver. I have thought about going custom cam, thats probably whats going to happen considering my lack of knowledge in that area.
My reason for not going straight there, is that I was not even planning on buying this expensive of a head combo but the deal was great so I jumped on it. Problem is that im already way over budget and I was hoping for a off the shelf cam to suit me well and save me 150$. I also already feel weird not rebuilding my engine and strange not putting new cam bearings in with a $160 cam. I think it would be risky doing it with a $325 dollar cam. Or am I wrong? The car has 117k
If i dont decide to go custom, what are the typical guidelines for as far as max lift max duration. Like is only 500 lift with 220 duration the max or is 530 with 218 usually safe? That kind of thing.
i'm a big fan of the comp xtreme energy cams. all the feedback i hear about them is very positive. you can go as high as the xe-262-hr without piston to valve clearance issues; i think the ex-274-hr will fit too, but i have not seen definitive info about that. i think they run about $250 or so
Hey ... don't feel like you are all alone on understanding cams and all that
goes with them :)
I do feel I got a good bit of general knowledge when it comes to modding
sbf's but most of my experience was back in the 60's and 70's.
When I got back in this hobby things had changed so much with the long
runner intakes, roller cams, and the like :crazy:
A thought or two for you on my experience with a Custom Guy :D
I went with a hired gun to kill my cam concerns for several reasons
but
Proven successful results was the main reason :nice:
You can tap into that fellows knowledge database :hail2:
and
Not have concerns about your lack of knowledge in that area :Word:
Those guys have the ability to listen to what you want and based upon
what you tell them ... they basically will tell you three things
1) You need a cam with such and such specs
2) You will need these specific parts to go along with that cam
3) Expect your Stang to behave like this
Here is where most peeps don't understand a benefit of this method
You tell the guy what you ... THINK ... you want at the time :banana:
When you get the ... STRAIGHT SCOOP ... form him :eek:
You may find what it takes to make that happen :shock:
is not what you can deal with :nono:
Quick Example
You tell him you want 400rwhp NA using your OEM block :)
He comes back and tells you .....
It will need to idle at 1000 to 1200 rpm
It will have a very soft low end
and
To counter act that soft low end ... you'll need 410's or better yet 430's
You'll need big headers ... something like Kooks, etc
It will not have drivability anywhere close to a stocker
etc etc etc
After hearing all that :crazy:
You QUICKLY realize ........
Your lowered dd Stang ain't gonna be practical for a combo that radical :(
The outcome and benefit of all that is :D
You amend your first plan to one that is more practical for your dd :nice:
AND
You can be confident that he is guiding you with accurate experience :Word:
My young friend ... Your thinking is slightly flawed here :Word:
What you DON'T have here is ........... a problem :(
What you DO have here is ............... an opportunity :)
You now have heads in the best category
as opposed
To heads that would be considered to be in the good category
Another thing you have going for you is .........
Great heads but at a price you can most likely get your money back out of
I know you are college bound and money it tight :crazy:
Just relax and save up a bit more :)
and
Make a plan that is worthy of those quality heads :Word:
I assure you ... It will all be worth the wait to do it right ;)
You should be able to find an ots cam that will work pretty good :nice:
Look at some of my old posts to see what others have done with those
heads and using an ots cam :Word:
Just remember this ..............
If you change your mind after doing an ots cam ...............
You gotta do gaskets, oil/filter, coolant, and all that work ... TWICE :bang:
and
If you don't do your own work ....
you gotta pay for the labor all over again as well :(
I've said more than enough for now but if you have any more Q's .......
I'll try to help ... if I can :)
Grady
Torked - Since money is tight, be patient:) College comes first, play comes second...
Remember, lift is not a factor for piston to valve clearance, but it can be one of the factors that causes valve float (lose control of the valve) and coil bind (the spring becomes full compressed and can break).
Duration is a bit more accurate in terms of piston to valve clearance, but not all of it. There is many combinations of opening and closing points that can determine how long a valve is open, which is duration.
Do not worry about cam bearings, many do the swap with 150k plus with the stock cam bearings. I swapped mine at 142k and I used that combination until 162k, and daily drover with no end in sight...
The trickflow stage 1 camshaft is a great budget camshaft for the foxbodies. The sn-95 computer (94-95 cars) have a pickier computer so I am not sure how the valve events with respond to the computer's wants. This is something that hopefully someone can help you with that is running the Trickflow Stage 1 camshaft.
You have great heads, and a good intake.
If you can swing for a custom camshaft, you need to be thinking that you will need a spring upgrade and they are incredibly well engineered and need some better engineered parts.
If money is tight, I would not worry about it. Just keep hitting the books...
Therefore, it will lend you better opportunities in the future to get 1, 2, or even 3 custom camshafts, for the many vehicles you may own:D
Adam - Good post, I have not read over that in a while, so it was good to get a refresher:nice:
Alright, you guys really kinda hit something cause I am not thinking. Why buy these expensive heads and a bigger intake if im not willing to spend an extra 125-150 dollars to make the cam pull the most out of my new combo. I really appreciate the help. Cant wait haha. Gonna have to wait til spring break to get this swap done though:notnice: oh well nicer weather means ill drive more haha. Thanks again.
