  • 1994 - 1995 Specific Tech
another "it doesnt run" thread...
  • Thread starter Thread starter mustang6tee8
  • Start date Start date Jan 10, 2007
mustang6tee8
375
College Station, TX
Jan 10, 2007
  • Jan 10, 2007
After fixing the timing cover, new HB, new hoses, t-stat, coolant, etc, the car starts up and runs great... for a little while. Today it started giving me problems. I was driving down the street in my neighborhood, and it died all of a sudden (kind of like what happens when the ground wire is faulty-but mine isn't)! When I was trying to turn the motor over, it sounds like it's not getting ANY fuel. All wiring is connected, everything is in place, except for this annoying setback. What should I do???
HISSIN50
34
129
Jan 10, 2007
  • Jan 10, 2007
A few guys in here have had the MAF not be secured and had a similar issue (I think Guero experienced this, for one). Just in case that's a possibility............
I'd check fuses real quick (there's a FP fuse under the hood).
Then toss the FP gauge on and see what's up.
A noid light can check for injector pulsing (an LED test light would probably suffice).
Do ensure you have spark as well.
If ya can narrow it down a little, we can help more.
Good luck.
mustang6tee8
375
College Station, TX
Jan 10, 2007
  • Jan 10, 2007
MAF is secured and fuses are all good...
..checking spark and hooking up FP guage next..
mustang6tee8
375
College Station, TX
Jan 11, 2007
  • Jan 11, 2007
Aha, I don't have spark!!! Fuel pressure is steady at 38psi.
HISSIN50
34
129
Jan 11, 2007
  • Jan 11, 2007
Fixored yet?
If no injector pulsing and no spark, think PIP (Profile Ignition Pick-up. The two-piece sensor in the distributor).
If injectors are pulsing but no spark, think TFI (Thick Film ignition. The ignition module on the passenger fender) or coil (or primary ignition wiring). Sometimes you can get yourself a KOEO IDM (Key-on Engine Off, Ignition Diagnostics Monitor. The IDM notes if the spark advance is where it should be. Kind of a system checker) or TFI code for this one. A test light across the coil terminals should make your test light flash like a pulsar (even while cranking only). The coil gets key-on constant 12 volts, and the ground pulse comes via the TFI/puter/PIP/etc going backwards (the computer controls the ground pathway, in other words).
Good luck.
mustang6tee8
375
College Station, TX
Jan 11, 2007
  • Jan 11, 2007
Injectors are pulsing, yet no spark.
I'm a little behind the times on these acronyms. Could you explain? Thanks for your help JT, as always..
HISSIN50
34
129
Jan 11, 2007
  • Jan 11, 2007
I edited the post with more than the horribly spartan info I normally post.
If you have injector pulsing, you know the PIP is good. Check across the coil terimnals (see if it lights up your testing light while cranking). This will tell ya if the issue is before the coil.
If the test light flashes, put your inductive timing light on the coil wire and see if it will make the timing light pulse. Go from there.........
Good luck bud.
mustang6tee8
375
College Station, TX
Jan 12, 2007
  • Jan 12, 2007
Got a new coil..no luck there. Testing ICM thingy next.
drakesdad
961
Oregon OHIO
Jan 12, 2007
  • Jan 12, 2007
edited.........disregard
mustang6tee8
375
College Station, TX
Jan 12, 2007
#10
  • Jan 12, 2007
  • #10
Update: Timing light does not light up.
mustang6tee8
375
College Station, TX
Jan 13, 2007
#11
  • Jan 13, 2007
  • #11
Update: this is really annoying.... I'm going to buy a new ICM to see if it will fix it.
HISSIN50
34
129
Jan 13, 2007
#12
  • Jan 13, 2007
  • #12
Wade, check your PM's
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
