All I need to know is, I finally found the PCV valve today now that I had some light to work with.
But I stuck my hand back thier and fet around, and on the tube that goes to the valve itself there was a lot of oil back their. Does this mean for sure that its stopped up and needs replacing? Or is this normal? Its getting replaced anyways, just wanted to know what to look for on future times.
Also, how in the world do you set the TPS? I used a voltmeter today and got everything like it should. It was showing amps and everything, and I tried to change it so I took the screws out and twisted it. But the screws will only mount in one location, so you cant really change it. Is their something im missing?
Dave
But I stuck my hand back thier and fet around, and on the tube that goes to the valve itself there was a lot of oil back their. Does this mean for sure that its stopped up and needs replacing? Or is this normal? Its getting replaced anyways, just wanted to know what to look for on future times.Also, how in the world do you set the TPS? I used a voltmeter today and got everything like it should. It was showing amps and everything, and I tried to change it so I took the screws out and twisted it. But the screws will only mount in one location, so you cant really change it. Is their something im missing?
Dave
