  • SN95 4.6L Mustang Tech
another pro50 install question
  • Thread starter Thread starter swl987
  • Start date Start date Jul 18, 2004
swl987
200
Cleveland,Oh
Jul 18, 2004
  • Jul 18, 2004
the instructions say to cut the center out of the main boot. is that the big one attached to the bracket or the little one on the piece you take off to expose the trans. how should i clean the old rtv off.THANK YOU
Snarf
237
Lexington, KY
Jul 18, 2004
  • Jul 18, 2004
Main boot is the one stapled to the brass bracket. The little one is a 'dust boot'. Just use a razor on the old silicone and TAKE YOUR TIME and dont drop any crap in the shift box.
twogts4us
4,188
12
79
Dunedin, FL
Jul 18, 2004
  • Jul 18, 2004
...and be careful with the razor, you don't want to gouge the metal. As Snarf said, and probably the best instructions you'll get, "Take Your Time". My wife did her own shifter swap on her 01 GT, with me supervising of course! It's really pretty easy and straight-forward swap and as you get into it you'll get a better understanding of how it works.
E
edwardohaskillo
120
The Land of Milk and Honey
Jul 18, 2004
  • Jul 18, 2004
Dude, DON'T CUT THAT BOOT! You don't have to. I pulled the dust boot off the original shifter and put it on the Pro 50. It's a little tight, but it will fit. I then installed the "floor board" boot (uncut, of course) over the shifter handle. I pulled it down 'til the shifter hole nestled between the two shifter handle bolts ( If you push it down past the bottom bolt it might bind).
This way The shifter mechanism is protected from road grit by the old shifter boot, and the floor board boot remains cherry. Plus there is one more layer of rubber between the cockpit and the tranny, Making for a quieter ride!
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 4, 2026
JD1964
