another problem uncovered...
  • Thread starter Thread starter bsmotorsports
  • Start date Start date Dec 16, 2005
bsmotorsports
  • Dec 16, 2005
Well, just bought this 89 5.0 lx. Damn nice car. Fixed the temp gauge in it and it seems to be running a little hot.
The car is running about exactly half way up the gauge, and at a dead stop it wants to climb a little more. I told my bro to stop driving it and well have to fix the prob.
The previous owner stated the radiator was brand new, and it looks it. We replaced the cap also. What could be causing this?
When the car is running I can grab the upper radiator hose and its hot, so water is flowing through. Could it be thermostat?
bsmotorsports
  • Dec 16, 2005
oops, sorry, it double posted, not sure why??
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Dec 16, 2005
  • Dec 16, 2005
free post!!!
RYC CUKR
1,437
Orlando
Dec 16, 2005
  • Dec 16, 2005
Could be several things
Alot of times when the temp starts climbing at idle it usually ends up being an air flow problem. Does the car still have the fan shroud on it? Can you see if it has been leaking fluid from the fan clutch? Stuff like that. Especially if it does have a new radiator I would look towards airflow issues.
I had the same type of issues with my 93. put a 3g alternator and a taurus fan on it and no more climbing temps.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Dec 16, 2005
  • Dec 16, 2005
A thermostat slows the coolant down so it can spend more time in the radiator (heat exchanger) - It's a $5.00 part so I would check there first.
To tell if the fan clutch is bad..... Get the motor up to operating temperature and turn it off (with the hood open) If the fan takes a long time to stop [ more than 10 revolutions ] than the clutch is likely out.
Look at the bottom of the car to verify that the black plastic air dam is present. Although not the culprit at low speeds it's a good idea to know that it's there.
Once you have eliminated all of these vairables, try changing the coolant / water mixture to verify that you have the correct ratio of fluid in there. Too much coolant leads to higher temps
After that, the only thing left is a bad water pump.
M
Marlboro_Man
437
Houston, TX
Dec 16, 2005
  • Dec 16, 2005
Hey is this bsmotorsports from h-i / houston?
If so i'm Matt, the one that gave you that integra service manual on cd a while back.
lmk if so i might be able to help you sometime with the car or at least maybe point you in the direction of someone who can.
Dbeck002
710
South florida
Dec 17, 2005
  • Dec 17, 2005
Airflow problem for sure. Get a new fan or an electric fan.
Paul Perreca
1,085
  • Dec 17, 2005
check chilton for the correct cap pressure - a certain lbs i believe it would be measured in, if it's the wrong lbs, it could be leaking while driving, or just after shut off -
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
