  • 1994 - 1995 Specific Tech
another question.....
  • Thread starter Thread starter MI95Cobra
  • Start date Start date Sep 23, 2006
MI95Cobra
451
Oklahoma City
Sep 23, 2006
  • Sep 23, 2006
hey what would cause my car to hesitate when starting...i mean it turns over and starts but sometimes it turns over several times before starting...i changed my distributor cap and rotor...checked my plugs....could it be my ignition coil????
AznStanger3v
2,026
Northern VA
Sep 24, 2006
  • Sep 24, 2006
fuel fuel fuel
spray some carb cleaner while someone is trying to start that beast and see if it fires right up. if it does.... fuel pump time (unless a restricition is found in the fuel system) ie: fuel filter, kink in line, something random.
HISSIN50
34
129
Sep 24, 2006
  • Sep 24, 2006
You can also simply cycle the key a couple times (let the pump prime, turn the key off, and repeat a couple times). Then crank it over for the first time. If it starts right up, it's likely a fuel issue (above-mentioned restriction, weak pump check-valve, FPR, etc).
Good luck.
MI95Cobra
451
Oklahoma City
Sep 24, 2006
  • Sep 24, 2006
ok....so your saying its most likely not an ignition coil...??? should i change the fuel filter...????
True 5.0
237
Southeastern Wisconsin
Sep 24, 2006
  • Sep 24, 2006
I agree. Start by changing the fuel filter as it is easy to do and cheap. If that doesn't fix your problem, look at a new fuel pump.
MI95Cobra
451
Oklahoma City
Sep 24, 2006
  • Sep 24, 2006
ok...thanks....
94_302
438
Miami
Sep 24, 2006
  • Sep 24, 2006
Do you have underdrives? I have underdrives and have noticed this since I installed them. Although the car does not get run that much, so the down time between starts may explain it.
MI95Cobra
451
Oklahoma City
Sep 24, 2006
  • Sep 24, 2006
no underdrive pulleys yet.....
xr8d302
I bought a 27" monitor to compensate for my lack o
Apr 29, 2004
1,113
Medicine Hat, AB
Sep 24, 2006
  • Sep 24, 2006
Do as HISSIN50 said, easiest test for the fuel system....
other possible problems could be:
faulty coil
faulty profile ignition pick up
faulty fuel system components besides the filter (i.e obstructions or kinks in the line)
Also, if you have equal length headers, they are pretty close to your starter, and after a while, too much heat can wear out the factory unit.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
