Another RR Question?
  • Thread starter Thread starter KG94GT
  • Start date Start date Dec 16, 2003
KG94GT
71
Virginia
Dec 16, 2003
  • Dec 16, 2003
Will 1.6 rollers rockers fit underneath stock valve covers? My TF plenum hangs over the drivers side cover big time so I'm thinking bigger covers might not work/fit.. and do you think it's a worthwhile addition (a few HP gain)to my existing mods! Thanks!
KG
bmo37
2,368
New Jersey
Dec 16, 2003
  • Dec 16, 2003
KG
should fit remove the baffle and your good, also you can always get an intake spacer with taller valve covers.
KG94GT
71
Virginia
Dec 16, 2003
  • Dec 16, 2003
Tks, lots of rr's to choose from. Not sure which one$ yet. Any reccomendations? Aluminum or steel, roller tips or a full roller? I'm not too familar with them... Tks!
makarov
180
Forestville, CA
Dec 16, 2003
  • Dec 16, 2003
bmo is right, remove the baffle and they should fit. Most head/cam manufacturers recommend full roller alumininum rockers. Unless you're a serious "class racer" there are all kinds of brands and prices. FRPP, harland-sharp, tfs, crane, etc. All are good, most are inaccurate. I read of an nmra racer who had to buy 3 sets of tfs rr's to get a full set of "true" 1.6 rockers, as they are torn down and measured, and must be actually 1.6. Not even crane "golds" were as accurate as the tfs rr's. Nothing to worry about on street or occassional strip use. I'm going to use the frpp setup.
KG94GT
71
Virginia
Dec 16, 2003
  • Dec 16, 2003
Tks Mak,
Aluminum sounds good but I'm still a little confused on which ones you reccomend. TFS or FRPP? I must have read your post wrong? Sounds like it's hit or miss with these things as far as precision made?
KG
makarov
180
Forestville, CA
Dec 16, 2003
  • Dec 16, 2003
I recommend all of them, I'm just going to use the ford rr's. The trick flows were the most accurate in tolerance that the guy could find. But like I said, his was "race only" and had to to spec'd exactly. On a daily driver/occasional strip car, I don't think that kind of accuracy is necessary. The nmra people are looking for cheaters, so they have to maintain tight specs.
As far as aluminum rr's go, I would guess that the head/cam manufacturers want the best numbers for their products, and the full rr's are lighter and faster than steel, less rolling resistance. That's why they're big, fat suckers that won't fit under your covers without removing the baffle. They are lighter, but if built to the same specs as steel they wouldn't last 10 minutes before breaking. Hope that helps you out.
94Blue302GT
704
Chicago
Dec 16, 2003
  • Dec 16, 2003
wait wait wait...
i thought that we had 1.6's stock?
replacing them with new ones will just make is smother right?
KG94GT
71
Virginia
Dec 16, 2003
  • Dec 16, 2003
Mak,
Gotcha, tks for the time to answer my question! I appreciate it! Full aluminum rr's it is!
KG
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
