Another spring question...???
THEPATRIOT
11
Sorry i know this has been talked about over and over.I have an "86 GT vert,and need new springs.I want the car to be level front/rear and sit just over the tires.I don't need it to be "slammed" but don't want large w.well gaps either(a decent ride too).Any good vert springs i should look at???With all the choices,it's making me CRAZY!!! :shrug:
Hi.
You have a few considerations that means that the typical examples do not fully apply to your car.
1) You have a heavy vert. So, the car will sit lower on a given set of springs.
2) The extra weight means that the car has more kinetic energy as it goes over a bump. So, you need heavy springs.
3) YOU HAVE A FOUR EYE with VERY LITTLE fender/tire clearance. Many people with a 92/93 just can't seem to be able to comprehend that "for some reason" Ford didn't keep the Mustang exactly in all aspects since '64! ;)
4) You can lower a pre-86. But, many people that BRAG about their lowered 4-eye seem to often forget to tell about the REQUIRED mods or tradeoffs! Most people will roll the fenders (which *I* will not do on my car), push out the front fender bottom support, and/or run some POS tire that has it's width over stated!
5) The rack of a car can be very personal. For some people, they are very picky about the rake. If you're that type, then IMHO you have ONE good/proper option - get the MM adj rear arms. At ~$400+, there aren't cheap. But, IMHO, every other rear adj arm is a POS and I don't think that cars that have them should even be allowed on public streets.
6) To be honest, and looking at it from a mechanical engineering point of view, you have limited options for a vert. Every option will result in a harsher ride.
7) If you don't have subframes on the car, then you MUST get them before you put on heavier springs. The notch is a POS design that has the stiffness of a wet noodle. The hatch (most typical) is worse. And the verts have the stiffness of jello. :) So, people that put on stiffer springs without first welding on subframes end up with a car that handles like cr*p and is twisting itself to ruin.
8) IMHO, your best bet is to go with a similar setup to what I have. If you live in a area with good roads (a myth in New England :)), then you might want to go with the Bullitt springs and the Steeda spacers up front. In the back, Bullitt springs and MM adj rear arms. The Bullitt springs will be roughly 0.2" -> 0.3" lower.
9) Mods can make a huge difference!
Alum heads remove weight from the front. A 3-core radiator (like I have) adds weight because of the added water. Etc.
10) Do NOT believe the PURE AND TOTAL BS that all tires of a given size (ex: 245/45/17) have the same height, or width, or tread patch, or will clear a wheel well the same. Just check out the specs on tirerack. My 245/45/17's have one of the widest tread patches of a tire that size. That's why I went with them. That also means that I have less fender clearance than a "typical 245/45/17".
Good Luck!
I have an 86 convertible, If you don't have subframe connectors, get them, but take the car to a body shop with a freme machine first, if the car has been driven, it will be out of square. Make sure that the frame is straight before the connectors go in. I put 1990 spindles and brakes up front and a set of 93 cobra struts. I have MAC upper and lower contol arms in the back, and ford racing "C" springs all the way around.
The sway bars are stock, with kumho 245/50-16 on pony wheels, From the top of the wheelwell, I am 24 7/8 off the ground in fron, and 25 1/2 in the rear.The car handles great, corners very flat, but it does ride a bit harder than stock, I can really feel the road under the car, and my doors rattle a bit more.Hope this helps
