  • 1994 - 1995 Specific Tech
Another summit radiator thread!!!
  • Thread starter Thread starter urban96
  • Start date Start date May 12, 2005
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 12, 2005
  • May 12, 2005
ok i searched and have good info on how to install it.
First of all these pics everything was a little dirty anyway what you have to do is there are two mounts that actually hold the radiator in place that have to be removed to get the original out. The top drivers side mount you need to keep. After removing the radiator you slide the new one into place with ease, then that top mount you take the rubber grommet piece and turn it around, basically remove it and stick it back in facing the opposite direction, then you will find a small hole on the bottom drivers side near the radiator tank that you can take a bolt and nut and bolt the old upper bracket to and place the rubber grommet against the radiator to hold it in place, and amazingly the way it fits in there it is snug and does not move at all!! The electric fan is up to you how you want to do that, I used zip ties temporarily but the auto stores sell the special electric fan mounts that go thru the radiator and hold it in place, not sure how to explain but they should know what you mean when you ask for them, comes in a pack of 4. you need a 1/8x3/8 pipe threaded fitting to hook up the overflow line which isn't hooked up in the picture. In order to hook up the overflow bracket you have to cut (to seperate) the upper protruding edges and bend down the small portion that the bracket goes over and you should be good to go, of course you will have to slightly modify everything a little to get it to fit your application how you want it but it does work and great at that!
but i have a question on how to re-use the stock overflow, do i need any kind of adapter to connect the hose?
also i dont need to buy the universal mounting brackets.. correct?
urban96
3,464
Syracuse, NY
May 12, 2005
  • May 12, 2005
did some more research...
i need this http://store.summitracing.com/default.asp?target=partdetail.asp&part=EAR-984004ERL
and the stock line just connects to that?
urban96
3,464
Syracuse, NY
May 12, 2005
  • May 12, 2005
bump
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
May 12, 2005
  • May 12, 2005
From what I've read use you reuse the stock hose using that adapter. Yellowboss did this swap here's a pic
[/img]
9
94GTNJ
94
  • May 12, 2005
Yes you need what you pictured, all you gotta do is connect stock line to that connector. I bought mine at an automotive store, was only like 4.99. I connected mine with a tiny hose clamp, although later on down the road I want to do something more eye pleasing.
No, dont bother buying summit universal rad kit. It was a waste, although I did use mine as a template (since it had the proper width of the radiator) for my custom brackets. Although I could have just used a tape measure.
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
M
1991 GT cigarette lighter/port not working (horn is working)
  • MartinM
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 30, 2025
MartinM
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
