I am frustrated - I just had a new centerforce dual friction clutch installed with a new pressure plate, t.o.b. and resurfaced flywheel less than 2k miles ago on my 1993 5.0 in my 1970 mustang because the throwout bearing was squeeling. Now the throwout bearing started squeeling again in a few hundred miles. It got worse so I just got the throwout bearing replaced again with a new Ford one yesterday and a new steel bearing retainer and it is still squeeking. It will still squeak even when the clutch pedal is pushed in to the point where the clutch starts to slip. It will not squeak when the clutch is pushed to the floor. I have completely loosened the clutch cable to where the throwout bearing is not contacting the pressure plate fingers and it is quiet only then when I pull up on the clutch pedal. The clutch cable will not come off the clutch pedal because it is secured up there unlike a Fox body Mustang so slackness is not an issue for the cable BUT the pedal now needs a spring to make it feel right and not let the throw out bearing drag on the pressure plate fingers. If I let the pedal just flop loose the squeak returns because the throwout bearing is touching the pressure plate. With the clutch cable adjusted really loose the friction point is really close to the floor but I can live with it - it does fully disengage and goes into all gears smoothly. I have heard there should be preload on the throwout bearing touching the pressure plate fingers for years BUT I have also heard there should be a gap too! This is completely opposite - both cannot be true. With it adjusted to have a gap it is quiet most of the time - except when I depress the clutch to shift a gear and it will squeak for just that instant when it contacts the fingers. Any ideas on what else can be done. Should I go back in and re-replace EVERYTHING? Clutch fork, pivot, T.O.B., bearing retainer, pressure plate, cable, .... This is getting very expensive and time consuming. I am tempted to fit some sort of return cable inside my dash to the clutch pedal assembly to get it to return all the way up when the cable is adjusted so loose - that seems to be the way this set up wants to work the best. Also - should the throwout bearing be greased before installing it? I put some white lithium grease on the new steel bearing retainer where it rides. Please help~!
