  • SN95 4.6L Mustang Tech
another trans thread...
  • Thread starter Thread starter mustang50v8
  • Start date Start date Apr 9, 2008
mustang50v8
548
847 Chicago Burbs
Apr 9, 2008
  • Apr 9, 2008
i think im going to change my trans fluid tomorrow or friday. question is the fluid, will i be ok if i pick up some Mobile 1 ATF from vatozone? or should i grab a different brand or type?
CobraRed_96_GT
1,421
UCSD/La Jolla
Apr 9, 2008
  • Apr 9, 2008
Question #1, auto or 5-speed?
another thing: I went to my local auto parts store and they only had 4 synthetic Mobil 1 ATF's - not too many people buy it bulk. I believe Walmart has quite a bit tho.
(I only buy oil and shotgun shells from Walmart)
mustang50v8
548
847 Chicago Burbs
Apr 9, 2008
  • Apr 9, 2008
its a 5-speed, i was under the impression that we are supposed to put ATF in there though
CobraRed_96_GT
1,421
UCSD/La Jolla
Apr 9, 2008
  • Apr 9, 2008
you can, i just wanted to know. Mobil 1 synthetic is rather decent - i'd recommend it.
mustang50v8
548
847 Chicago Burbs
Apr 9, 2008
  • Apr 9, 2008
well i was trying to find a good trans fluid and mobile 1 came highly recommended to me by a friend. i checked out the website and it passes all of fords and gm's "standards"
i really just want to stop the rock crushing / tumbling marbles sound in my trans when it is put into 5th gear.
BurningRubber
1,865
24
58
Apr 9, 2008
  • Apr 9, 2008
4 quarts of Mobil 1 Synthetic ATF will do you good.
It wont miracle fix anything but it is a good lubricant.
mustang50v8
548
847 Chicago Burbs
Apr 10, 2008
  • Apr 10, 2008
im not looking for miracles, just less marbles in the trans noises.
but like i said that only happens in 5th gear, and only for a minute after i put it there.
AdRock
521
South Texas
Apr 10, 2008
  • Apr 10, 2008
If you hacve the TR3650 trans only put 3.2 quarts in it. The trans will be a little noisy but 3.2 is the correct level. If you put all 4 quarts in it it's possible that it can get tougher to shift.
mustang50v8
548
847 Chicago Burbs
Apr 10, 2008
  • Apr 10, 2008
are there any special tools i need to change the trans fluid, how do you pour the new fluid in? the filler hole is kind of tight to get to. so im assuming that i will needs some sort of toll to get that done
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
