Another WHAT WILL SHE RUN???
  • Thread starter Thread starter Sergi_91
  • Start date Start date Nov 28, 2005
Sergi_91
montana
Nov 28, 2005
  • Nov 28, 2005
Okay, I know TAKE IT TO THE TRACK. I have had my license suspended for 3 years for driving recklessly and riding wheelies on my motorcycle. Well I got rid of the bike, and kept my 92 Mustang GT when this happened. So I figured this was a ****ty thing, but a good oppurtunity to upgrade my mustang to where I wanted it to be.
I planned my car out to be more of a track car, and started going "window shopping." Now I got a road and track suspension kit from maximum motorsports, The Baer Claw kit for 4 wheel disc brakes, a t56 tranny, and moser 31 spline axles with 3.55 gears.
For the engine I wanted it to be capable of high rpms for plans of a twin turbo setup. I got a super pro bullett 331 long block from DSS with AFR 205s and had the Hi-Rev upgrade installed. The pistins are 8.5:1 compression. It has a main girdle support and a windage tray. I am running a trick flow r series intake a 90mm throttle body and maf. A hellion twin turbo kit with 72mm turbos and a intercooler. The boost on the turbo is at 14 psi, and the engine and turbos are capable of more, but I am leaving it there for the time being.
Now, for the reason I haven't taken it to the track yet is because I finished it and got my license at about the same time, but now the track is closed, and it started snowing her last night so I don't even get a chance to drive to break the engine in. Now to see anything I have to wait til spring. But I am curious to see what stangnet thinks this will run.
I
IntenseBlue
946
  • Nov 28, 2005
Since when does Hellion make twin turbo kits?
Modular2v
3,222
23
99
oklahoma
Nov 28, 2005
  • Nov 28, 2005
i think they have for awhile now
T
tony91723
71
  • Nov 28, 2005
yep. its going to be fast as hell. I say low 12's first and then with some time behind the wheel I see even greater things. good luck man.
Paul Perreca
1,085
  • Nov 28, 2005
i see mid 10's w/ traction
skip nay
110
Chambersburg Pa
Nov 28, 2005
  • Nov 28, 2005
A friend of mine with about 20 lbs single turbo boost and a 306 has gone 9's so I would say if your tranny holds up and you can shift I would say low low 10's.
I
IntenseBlue
946
  • Nov 28, 2005
Didn't realize they made tt kits for foxes. Didn't know they offered 72mm turbos either. Oh well.
$uperstang
476
Detroit, MI
Nov 29, 2005
  • Nov 29, 2005
low 10's for sure with traction!
just4bob50
504
Pa.
Nov 29, 2005
  • Nov 29, 2005
I dont know about the ET because of traction, but i bet you get close to 130 mph in the traps on a 1/4 mile track.
SQUEEZE&STROKE
SOUTHERN CA
Nov 29, 2005
#10
  • Nov 29, 2005
  • #10
Well I have a friend with a single turbo (6X mm something turbo...pretty small) 347 in his fox. On street tires he regularily traps 126 uncorrected (2710 ft above sea level) and goes low 12's with a 1.9 or 2.0 60'. Thats on stock goodyear 245/45/17's
droptop93
1,497
Lake Mary, Florida
Nov 30, 2005
#11
  • Nov 30, 2005
  • #11
well i wouldn't suggest trapping much over 130 because that stock block will split, girdle or not.
My car made 510/576 with 14psi on a Mustang dyno, and trapped 130 falling on its face off the line (no 2-step...2.5 60')
since it's setup for road racing, I don't think 10's are going to happen...but some high trap speeds will be for sure.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
