Answer this quiz
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Jul 10, 2010
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jul 10, 2010
  • Jul 10, 2010
Ok tell me,what temp your car runs at.What cubic in.what you use antifreeze/water etc.what your normal temp is where you live.elec fan or clutch fan.peace
john
Adams91LX
689
12
29
Plano, TX
Jul 10, 2010
  • Jul 10, 2010
I usually run on or around R-M, stock fan, prestone 50/50, in the summer 95+ right now in ABQ
Does that help?
R-M range
old_blue
1,783
282
124
Jul 10, 2010
  • Jul 10, 2010
I just put in a 180 thermostat and it is a-l range.stock 302 stock fan and 50/50 prestone.I think I am going to put in a 195 thermostat though. Seems to low. FOr here in Az I thought cooler was better.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jul 10, 2010
  • Jul 10, 2010
hummmm? i have 1/2 gallon antifreeze the rest water with redline water wetter. i run about 180ish without the fan on when driving on the freeway.peace
john
89stang1
Stroked and Juiced
730
234
74
nj
Jul 10, 2010
  • Jul 10, 2010
john
I used Watter Wetter for a while until i could clearly see lots of gunk, almost will make u think u blew a head gasket by what u see in rad. as soon as i got that stuff out of my system i have never seen a trace of that gunk anymore so becareful with that stuff............even tho it did lower my temps....now i use the stuff they sell at Autozone Hy-Per Lube Super Coolant seem to work as good without the gunk
F
fivepointNO
746
  • Jul 10, 2010
I use mostly water and a touch of water wetter, run a 195 T-stat, dual electric fans, and stay at about 190* and up to 205ish. Florida is hot. 408cubes. I still run a brass 3-core radiator as well.
cenok is family
1,409
69
79
Norman, Ok
Jul 11, 2010
  • Jul 11, 2010
308ci. about 50/50 anti-freeze/water...i guesstimate. she usually runs around 180ish (top of "A" in "NORMAL"). completely stock cooling system (radiator/fan/waterpump/etc.) with a 180 t-stat. just started installing a taurus fan with DC controller today though. would have finished if my girlfriend didn't whine about spending time with her on her day off . i'll let you know how well the fan/controller work tomorrow.
metalman85
41
Lansing, MI
Jul 11, 2010
  • Jul 11, 2010
351 cubes, 50/50 antifreeze/water. bottle of redline. 185 t-stat. electric fans (which i dont ever use) i can sit at a stop light on a 90* day and it wont idle over 200-205. runs at 185 all day long down the road. stock water pump, stock 5.0 radiator.
metalman85
41
Lansing, MI
Jul 11, 2010
  • Jul 11, 2010
good to know! i'll keep an eye out for build up. i'll have to try the super coolant if it gets bad.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jul 12, 2010
#10
  • Jul 12, 2010
  • #10
Ok thanks guys,so i guess running 185-200* isnt bad? I usually run 190 +/- peace
john
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
Jul 12, 2010
#11
  • Jul 12, 2010
  • #11
Runs between 195-205 degrees on hot days, which are 90-100 around here
Blown 302
50/50 coolant
electric fan
and for extra credit, I run a 3-core Fluidyne
brands5.0
577
miami ,florida
Jul 12, 2010
#12
  • Jul 12, 2010
  • #12
If you use water make sure its Distilled water and redline.
Chrome_Rust
530
Findlay, Ohio
Jul 12, 2010
#13
  • Jul 12, 2010
  • #13
70/30 coolant, 160 t-stat, stock WP, UDP's, stock Rad, 308 CI, Milled heads, Elec Fan (runs 100%) with the A/C off runs 160ish, A/C on 195-210. I live in NW ohio
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jul 13, 2010
#14
  • Jul 13, 2010
  • #14
i'm hoping to be back there soon 1 day! i grew up in a suburb of columbus for 25 years. peace
john
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
