- Apr 29, 2011
- 3
- 0
- 0
Good evening guys new to stang net but I'm having problems with my stang. Ok to give you guys the low down I have an 87 Gt that I have done a few things to. Added GT40 heads, trick flow stage 1 cam, Trick flow intake, 70 mm thottle body, long tube headers, new water pump, after market radiator and over flow, and converted to mass air.
So after I have done all of this the car is running great but it takes a long time for the motor to warm up but when it dose finally warm up the antifreeze overflows out of the radiator and dosent stop.
I have had a pressure test done to the cylinders but no leaks in the head gaskets, intake gaskets installed properly and belt routed in the right direction. I think that there is a flow problem but I have no idea where to start.
Could i have possibly got the wrong water pump that looks like the origonal one?
