Anti-theft
92 LX
78
Since I live in a rather rough town, I was thinkning of incorporating an anti-carjacking switch in my '92 LX. My plan is to get a factory fog light switch and splice into the clutch pedal / start switch wire so before anyone can start my car, the "fog lights" would have to be turned on. Once started, I could turn the switch off. Do you guys see any problems with this idea?
Thanks for any and all input.
As always, you guys are the greatest. :nice:
Greg
The easiest thing to do is get a security lock switch, those round key switch lock keys use to arm security alarms, and a relay. Hook in to the ignition system at the ignition switch in the column. Break the circuit there and connect it to the relay on the normally closed side. You want the switch to energize the relay and pull the relay to break the connection to the Ignition circuit when in kill mode. The current draw is not that much so your battery sould be just fine.
The hardest part is finding a location to place the switch and to make it so it cant be bypassed. I would place it in that useless ashtray compartment under the tray. That way the switch and wires are under the car and if your car is lowered very hard to get to.
