Antifreeze mix
  • Thread starter Thread starter foxbody1989
  • Start date Start date Sep 19, 2010
foxbody1989
61
Tacoma, WA
Sep 19, 2010
  • Sep 19, 2010
I was wondering if you had a bad mix more antifreeze than water could that cause overheating? What happens when you have more antifreeze than water could it cost probs?
HISSIN50
34
129
Sep 19, 2010
  • Sep 19, 2010
Water transfers heat about 2.6 times more efficiently than E/G coolant. So running a richer mixture than necessary can reduce efficiency.
foxbody1989
61
Tacoma, WA
Sep 19, 2010
  • Sep 19, 2010
Thanks
Ok my concern is my system was flushed by the shop. And this antifreeze looks neon green almost like there is no water and i noticed my temp gauge goes up after the car is turned off never did it before.
Mustang5L5
Mod Dude
Feb 18, 2001
43,389
18,130
224
Massachusetts
Sep 19, 2010
  • Sep 19, 2010
Where are you located?
Drain the radiator and add a gallon or so of distilled water and the rest 50/50 mix
What's the condition of the radiator? Gunk on the internal fins? Possible the flush dislodged and clogged the radiator a bit.
I wouldn't put much faith in the stock temp gauge rising when the car is turned off. In fact, imwould just ignore that. Does the temp gauge read normal when the car runs? If so, then you are all set. When the coolant stops circulating, the temp will rise a bit. You have 190 degree coolant sitting inside a huge heat sink of an engine with temps above the coolant temp. Normal fpr it to rise when turned off. Also, I don't believe the stock gauges move when car is off. My temp gauge stays where it was when car was warm until I cycle the key to on.....then it drops.
Also, get a real gauge...the stocker blows monkey nuts
HISSIN50
34
129
Sep 19, 2010
  • Sep 19, 2010
I'd suggest you get an antifreeze tester (they're like a buck) and test yours. Otherwise, you're guessing about the ratio. With that objective data, you can take it back to the shop for a proper fill if you need to.
Cobra912
1,777
11
39
Wish I was anywhere but here
Sep 19, 2010
  • Sep 19, 2010
exactly.
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
1990 Mustang with no-start condition - Fixed and how-to
  • TTSaleen
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TTSaleen
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
